Fan clutch wire harness diagram needed
2006 FORD EXPLORER SPORT TRAC
20,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
JOHN SOILEAU
Fan clutch wire harness diagram needed.
Jun 23, 2018 at 1:54 AM
STEVE W.
  • 15,113 POSTS
This might help.
Pin 1 - Empty.
Pin 2 - Yellow with green trace = Power feed from battery for clutch.
Pin 3 - Blue with black trace = Fan control from PCM.
Pin 4 - Black with green trace = Ground.
Pin 5 - Gray with yellow trace = Fan Speed sense to PCM.
Pin 6 - Violet with green trace = Power feed from PCM for control circuit.
Jun 24, 2018 at 12:38 PM
Hi John,
Thanks for re-posting. Here are the fan clutch wiring diagrams which are in the engine wiring diagrams. Let me know if you are not on the phone and cannot enlarge the diagrams.
Here is a guide that can help:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jun 24, 2018 at 12:39 PM
