After I learned the reason why the fan motor blower only worked on high, I bought a new resistor online. I installed it, and tested the low, med and high settings. The settings worked, but then I noticed that smoke started coming off the resistor, so I immediately shut off the fan and turned the car off before permanent damage would occur.
Should I replace the fan motor? Clean the fan motor more thoroughly? Do something else?
Thanks,
Lorne
Thanks,
Lorne
Oct 20, 2016 at 1:24 PM
