Fan
2007 SATURN VUE
209,500 MILES
MSFAWN
When ignition is "off"and the keys are taken out, the fan keeps running. Until key is put back in, and ignition is switched over to "on" and then back to "off". Then fan will turn off.
Sep 6, 2017 at 2:40 PM
SATURNTECH9
  • 30,869 POSTS
Does the fan turn off after a few minutes of running with the key off?
Sep 6, 2017 at 7:53 PM
MSFAWN
Yes. It will run when on the on position I.turn it to "off". And seems to stop when I turn to "off", but then kicks back on. I then have to switch back to on again then the fan will turn back off again.
Sep 7, 2017 at 4:21 AM
MSFAWN
But no it will not shut off for minutes of the key being out.
Sep 7, 2017 at 6:21 AM
SATURNTECH9
  • 30,869 POSTS
If the engine is hot enough when you turn it off the fan can run for a little while until it reaches the correct temperature then turn itself off. how long are you waiting to see if it will go off by itself?
Sep 7, 2017 at 7:01 AM
SATURNTECH9
  • 30,869 POSTS
Also, which engine do you have?
Sep 7, 2017 at 7:02 AM
