All steering buttons and horn stopped working?
2010 MERCEDES BENZ C180
182,000 MILES • AUTOMATIC
MVULAZ MHLOPHE SONDIYA
I took a car to the mechanic on the 12th of October, and they changed a computer box. It came back fine but after 2 weeks all buttons in the steering stopped working together with the horn stopped working. The lights in the dash are on but cannot be changed if I press buttons in the steering. What could be the problem?
Nov 2, 2022 at 10:52 PM
CARADIODOC
  • 34,306 POSTS
You're describing the typical symptoms of a broken clock spring. That's a wound-up ribbon cable in a plastic housing under the steering wheel. This article does a better job of explaining how they work:
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
If you want to replace it yourself, take a look at this article first:
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Other car models are similar. I only have access to service information for models sold in the U.S. If you need instructions for your model, I'll post them for something similar.
Nov 3, 2022 at 10:48 AM
