failure in gear selection
1999 ISUZU OASIS
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
EMMAFURE
The transmission from first to other gear is not in sequence. There is a long delay in transmitting and sometimes it does not go beyond first for a long time. Then when it does it is like a bang and then a jerking movement then it will relapse to neutral again.
Also, the fuel consumption is high, even before this new problem. I have just changed the catalytic converter, yet the problem seems to persist.
Nov 1, 2016 at 12:44 AM
HMAC300
  • 48,601 POSTS
scan for codes and have a transmission professional look at transmission. It may be an internal problem or valve body problem.
Nov 1, 2016 at 6:06 AM
