Failed tune up, misfiring
2014 VOLKSWAGEN JETTA
125,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BEJG
Changed spark plugs continued to miss, not firing all four. Took those back got different kind. Changed the wires same problem. Changed the module since had 125,000 miles on it. Still missing, not firing a four cylinders. Car cannot go any faster then 35 mph. Sitting in the driveway since last weekend. We have tuned it up before and no problems.
Thanks ahead of time.
Oct 4, 2018 at 11:08 AM
It sounds like you have a head gasket blown between two cylinders but to confirm lets do a compression test.
and
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Oct 6, 2018 at 4:23 PM
BEJG
Was worried when I read your reply. Decided I better research "Yelp" in my area fir a reasonable VW mechanic. Talked to him on the phone. Thought at first could be a vacuum leak but actually after he was able to look at the car turns out it is two bad fuel injectors causing the problem. He did not charge for the diagnostic. Still expensive fix. Thanks anyways, appreciate you taking the time to reply.
Oct 9, 2018 at 5:37 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Oct 10, 2018 at 2:32 PM
