Which radio do you have, the base radio, the Bose with Nav, Bose w/o nav, Stereo without Bose with or without navigation? All are a bit different. You say you bench tested it and it works, how are you bench testing it? When you say it doesn't turn on, the only thing that does come on but then shuts off are the lights? Nothing else? Do you know the item or kit that was used on the converter? From the description I suspect the kit may have been wired in wrong and may have damaged the BCM or the security section of the radio, so it thinks it was stolen. Did it work for a while then stop or was it working, they installed the converter, and it hasn't worked since then?
Probably the first thing would be to scan it with a higher end scan tool and see if the radio and BCM are on the network and able to communicate. All versions are connected and it's possible that the scan would show at least if the data lines work.
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Feb 10, 2022 at 6:23 AM
