I have done the simple checks with the fuse out and battery connected. The high side of fuse holder F9 reads about 2400 Ohms. With battery in, I get battery voltage across the open fuse holder. Whatever is causing that fuse to blow does it when the fuse is replaced and the ignition key turned on. There is a power hold relay in the F9 circuit that evidently applies power to the ECM. How do I locate all these wires? If there are bared wires shorting to ground, I'd like to find them. What is causing the key to grab and not come out? What causes the shifter to not move? What causes the dashes in the odometer to display? Would appreciate any help. A garage gave me a wiring diagram of the F9 circuitry. odometer display is blank after self diagnostic all dashes.
Rene Melendez
Rene Melendez
May 1, 2020 at 3:22 PM
