extreme backfiring, loss of power, and hesitation...
1989 CADILLAC DEVILLE
125,000 MILES • 4.5L • V8 • FWD • AUTOMATIC
THEWOLF
My 1989 DeVille is experiencing extreme backfiring, hesitation, and loss of power/power surging. When driving the car it lags, then starts to hesitate/surge, and then backfires. I've blown both the Cat. , and the muffler. So far we've done a complete tune up, replaced the coil, and distributor, replaced the fuel pump, and the ECM(computer). The car seemed to mellow for about 50 miles after the computer was changed, but then reverted to it's old ways. Not sure what else is really left except maybe the timing chain, or maybe the crank or cam shaft. Also according to a different mechanic then the one currently changing all of the parts, spark, and pressure are good. So any help woukd be greatly appreciated...thanks.
Nov 10, 2014 at 1:15 PM
HMAC300
  • 48,601 POSTS
scan for codes and check firing order but it may be a head gasket or worn camshaft
Nov 10, 2014 at 4:10 PM
THEWOLF
Gonna assume a head gasket gone bad would result in compression loss somewhere in one of the cylinders, but compression is fine. Crank shaft is possible, and if that is what it is, is there a reliable test, or am I stuck with yanking the thing out for a look see? Something I forgot to mention is that it is worse under power. It will rough idle in park, but not as frequently, or as hard as when it is in drive. We also changed the smog pump. Something else of note...when the car is turned off after a little while there is a loud thump that sounds like something falling in the trunk, and feels like someone hit me in the rear neither being the case. I thought it was caused by the exhaust pipe cooling down, and the metal flexing. Not sure though.
Nov 10, 2014 at 4:52 PM
HMAC300
  • 48,601 POSTS
check for a vacuum leak and then pull valve covers off an see if valves are working properly that checks cam/lifters and pushrods. Would really need to see t his to diagnose correctly
Nov 11, 2014 at 5:59 AM
