After doing the timing belt, crank seal etc., I find myself with 3 bolts I can't remember where they were. One is a 12mm head with red Loctite and the other 2 are 10mm heads, one of which also has Loctite. I'm hoping the Loctite will be a clue. Getting old stinks when the memory fails you. Hoping you can help. I don't think they are down by the crank gear anywhere.
Sep 2, 2023 at 5:49 PM
