Possible fuel injectors replacement
2013 FORD ESCAPE
110,000 MILES • 2WD • AUTOMATIC
BENKENT2112
  • 7 POSTS
extent of damage not easily determined by mechanic. Friday, my vehicle started hard idle at a red light. Check engine light was flashing. I was 3 minutes from home. Got the car into the driveway and turned it off. I smelled gas. I had it towed to my mechanic, who called me on Saturday saying that the fuel injectors may need to be replaced but he wont be able to tell if any damage was done to the catalytic converter until he replaces the injection system. Does this sound right?
Oct 20, 2019 at 8:43 AM
BMDOUBLE
  • 1,139 POSTS
Yes it does because to evaluate the catalyst the engine needs to be running at stoichiometric ratio, (or normal fuel ratio in other words). You need to then evaluate the front vs rear oxygen sensor and catalyst monitors for proper operation, meaning the rear sensors (after cat) will need to be stable at .4-.6 volts. If they mirror the front (pre-catalytic converter) sensors and are switching from 0 to 1 volt like the pre-catalytic converter sensors,then the catalytic converter/s are bad. Excess fuel in the exhaust will cause the catalyst to overheat and crack the internal honeycomb structure and the material that it is made of. Here is a guide that will explain it further: https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Oct 20, 2019 at 9:16 AM
BENKENT2112
  • 7 POSTS
Could that type of damage happen that quickly?
Oct 20, 2019 at 9:20 AM
BMDOUBLE
  • 1,139 POSTS
Yes it is. I've seen catalyst get replaced only to go bad in a matter of minutes because a coil failed. Catalyst manufacturers often times will give a disclaimer that they will not warranty their catalytic converters if the vehicle has any driveability symptoms. But yours might be in good shape after the repair is done! I hope it turns out for the best!
Oct 20, 2019 at 10:32 AM
BENKENT2112
  • 7 POSTS
Here are the codes: P0301 P0316 P00c6-00
Oct 21, 2019 at 4:55 PM
BENKENT2112
  • 7 POSTS
Extent of damage not easily determined by mechanic. Friday, my vehicle started hard idle at a red light. Check engine light was flashing. I was 3 minutes from home. Got the car into the driveway and turned it off. I smelled gas. I had it towed to my mechanic, who called me on Saturday saying that the fuel injectors may need to be replaced but he wont be able to tell if any damage was done to the catalytic converter until he replaces the injection system. Here are the codes pulled: P0301 P0316 P00c-00. What are the chances that the fuel injectors are my only problem?
Oct 22, 2019 at 3:53 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
Direct Trouble Code[DTC] P0301 is a misfire in cylinder 1, DTC P0316 is for a misfire detected on startup[first 1000 revolutions], and I can't find DTC P00c00 anywhere on the list of DTC's for your vehicle. Is your vehicle's engine the turbo model?
Thanks,
Alex
2CarPros
BENKENT2112
  • 7 POSTS
No. It’s the eco boost.
STEVE W.
  • 15,113 POSTS
The Eco-Boost would be the turbo version. That is where they get the boost from. It's a small displacement engine with the turbocharger forcing it to act like a larger engine.
It could be a faulty injector, however it could also be a failing fuel pump.
P00c6-00 is a code for low fuel pressure while the engine is cranking. It can cause misfires and could easily cause the codes you have. The fuel smell could be a leak which caused the low pressure as well possibly at the cylinder 1 injector.
Oct 25, 2019 at 3:38 PM
BMDOUBLE
  • 1,139 POSTS
With these details in place I can see the possibility of a failed fuel injector! The low pressure code can set if an injector gets hung open and the flashing check engine light is due to the type A misfire. The light flashed anytime there is a possibility for catalyst damage.
Oct 26, 2019 at 7:45 AM
