Exhaust with no muffler or catalytic converter rides rough and sputters when accelerating
1996 GMC SIERRA
178,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BIGJOHN01
Truck rides rough and sputters when I get on the gas. After the truck gets hot, I can feel it clear up and drive better. Even the exhaust sounds better. Just had new exhaust pipes installed with no muffler.
Dec 8, 2016 at 6:56 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. See link.
also, check for a vacuum leak and soft vacuum hoses if soft replace them.
Dec 8, 2016 at 12:22 PM
Hey Bigjohn
It sounds like it could be a mass air flow sensor that has gone bad or is dirty, also scan for trouble codes, here are a couple of guides to help you,
https://www.2carpros.com/articles/mass-air-flow-service
and
Please let us know happens so it will help others.
Best, Ken
Dec 12, 2016 at 12:01 PM
BIGJOHN01
I've put new plugs, wires , cap and rotor. Replaced mass air flow sensor. New fuel filter, fuel pressure regulator and injectors. My exhaust broke loose and had to fix it cheap. Got a feeling it's either the throttle position sensor or the O2sensors
Dec 12, 2016 at 4:03 PM
Do you have an OBD2 plug? or is it an OBD1 truck?
Dec 12, 2016 at 4:17 PM
HMAC300
  • 48,601 POSTS
scan for codes that is one of the first things to do also check for a vacuum leak because it sounds like computer is richening the fuel mix to take care of vacuum leak also running with no cat and no secondary O2 is not a good idea.
Dec 12, 2016 at 4:39 PM
