Exhaust pop sound with misfire
2005 NISSAN BLUEBIRD
100,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
SIMPLEONE
  • 13 POSTS
Hi, My car (Nissan Bluebird Sylphy) gives a continuous popping sound from the exhaust. This only happens when the car comes to the operating temperature. An engine miss is also associated with this.
* Changed the spark plugs, Ignition coil
* MAF cleaned, air filter changed
My guess is the ECU get a too lean signal after reading the articles here. Any lead into what to look for will be greatly appreciated. Thank you
Jan 27, 2019 at 7:52 AM
Good morning
Yes, it sounds like it is running lean. It will cause this type of misfire in the system.
Is this gas or diesel?
I need to know to further help you.
Jan 27, 2019 at 8:42 AM
SIMPLEONE
  • 13 POSTS
Good Morning, It is running on gas (octane 92). Is there a possibility of a leak? There is a pop coming from the exhaust when the ignition is off after a trip. The pop frequency reduces to 0 within 30 seconds or so gradually.
Jan 27, 2019 at 8:47 AM
Thank you
I would start with a compression test. A burned exhaust valve will cause this issue.
https://www.2carpros.com/articles/engine-backfires-while-running
Beyond that I would verify timing. If the valve timing is off from a worn belt or chain, it will retard the timing and it will backfire from the exhaust.
https://www.2carpros.com/articles/how-a-timing-belt-works
Jan 27, 2019 at 8:51 AM
SIMPLEONE
  • 13 POSTS
Thank you for the reply. I will check the compression. That and the timing never crossed my mind because the car pulls great.
Jan 27, 2019 at 8:59 AM
Yep, but if the timing is off, it will backfire.
Jan 27, 2019 at 9:07 AM
SIMPLEONE
  • 13 POSTS
Alright compression and the timing I will get checked from a shop. The guides will help me to tell them what to do. What about the pop when ignition is off?
Jan 27, 2019 at 9:10 AM
Fuel burn off in the exhaust after turning it off.
Jan 27, 2019 at 9:12 AM
SIMPLEONE
  • 13 POSTS
Yes. That could be it. Thank you very much for the help. I will update here what fixed it for someone's future use.
Jan 27, 2019 at 10:29 AM
Your welcome
Always glad to help
Jan 27, 2019 at 10:33 AM
SIMPLEONE
  • 13 POSTS
Hello, Still couldn't go to a mechanic. But captured a sound file of the engine.
https://we.tl/t-pOIHNNqKry (Audio file link)
Jan 30, 2019 at 7:40 AM
Okay, sounds noisy.
When was the last time you had an overhead done?
Jan 30, 2019 at 7:55 AM
SIMPLEONE
  • 13 POSTS
Three years or so.
Jan 30, 2019 at 10:06 AM
SIMPLEONE
  • 13 POSTS
This is I am holding the phone over the engine block after fully warm up. It is not that noisy when the hood is closed. But it does sound like a diesel in the audio than a 1.5 liter gasoline. I am worried about that continuous ticking.
Jan 30, 2019 at 10:08 AM
I would start with having an overhead done. The valves sound like they are asking for an adjustment.
Jan 30, 2019 at 10:15 AM
SIMPLEONE
  • 13 POSTS
Thanks. I will post an update.
Jan 30, 2019 at 10:28 AM
Sounds like a plan.
Jan 30, 2019 at 10:33 AM
SIMPLEONE
  • 13 POSTS
Alright so got it tested with the mechanics. First they wanted to make sure the ignition coils are not leaking. Once that is eliminated, spark plugs were checked. Nothing wrong with that.Then cylinders and valves were cleaned by burning solvent through the PCV. After this engine became smoother and the misfire was reduced a lot. They advised to run for some time and see. If the problem doesn't go away, next is a throttle body cleanup and if not removing valve covers and deep cleaning.
Jan 31, 2019 at 2:15 AM
Sounds like they think it is carbon build up.
Jan 31, 2019 at 2:58 AM
SIMPLEONE
  • 13 POSTS
I guess so. What do you think? They said if these cleaning won't do they'll get to the timing. Which you advised earlier in the thread.
Jan 31, 2019 at 4:38 AM
Yep, I would have done the timing first to confirm it.
Feb 1, 2019 at 3:25 PM
SIMPLEONE
  • 13 POSTS
It turned out to be a bad coil. Misfire is gone for good and the exhaust pop is still there. Two different issues I guess. If I ignore the pop after switching off, everything is fine now.
Mar 4, 2019 at 3:55 AM
I would not ignore it at all. It may do more damage if you ignore it.
Mar 4, 2019 at 12:28 PM
