exhaust manifold overheating turn to color red
2003 TOYOTA PICKUP
4 CYL • 2WD • MANUAL
KEN13
The exhaust manifold of the engine turns to color red cause of heat we only overhaul that engine and we cancel the balancer inside the block i need your help please
Jul 21, 2014 at 9:20 AM
HMAC300
  • 48,601 POSTS
have a pro scan for codes and see if it's running to lean.
Jul 21, 2014 at 9:36 AM
KEN13
thank you for the info sir is there any posibility causes asides from that?
Jul 21, 2014 at 9:41 AM
HMAC300
  • 48,601 POSTS
possible clogged converter lean or rich condition maybe secondary air system not working as well if it has it.
Jul 21, 2014 at 9:45 AM
KEN13
thanks again sir we will chek and test first the 1st two sugestion you gave godbless
Jul 21, 2014 at 9:55 AM
