I'm wanting to look at changing the exhaust manifold gaskets since it looks like it's separated from the surface. Does it cause a noise like a hum noise as your driving that seems louder, and you go faster or give gas? I also am still losing oil somewhere and at one time a code in sufficient on exhaust (can't recall code way BK but reset and went away. likely caused from sitting at lights).
Is that one of the common sounds when a leak is present? There's no ticking.
Also do I have a few bolts that have nuts holding the exhaust cover on studs? And what technique besides using heat. would warming engine help? I don't have a torch but a heat gun. Hopefully a few use nuts, not bolts too.
Thanks
Thanks
Dec 27, 2024 at 10:58 AM
