Is there a way to set the exhaust cams without taking off the valve covers?
2003 KIA SORENTO
200,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
DAVID TODD
MEMBER
FOLLOW
Got my intake valves set, thank you for that bit of info. my cams were 180 out. I can't see the valves to tell which ones are opening and closing.
Aug 3, 2022 at 7:38 PM
CERTIFIED EXPERT
You will need to remove the valve cover to access the valves. Are you getting ticking or something that leads you to believe they are not properly adjusted? They should automatically adjust with this design.
