code p0340?
2007 HONDA CIVIC
180,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
ELIELG80
my cars check engine light when on, code p0340 the camshaft code.... its been running rough, it jerks on first gear, sometimes the transmissions feels harder, and occasionally it takes 2-3 tries to turn on. Anyways I bought a sensor on A1 auto and I installed it but the car cranked but did not start with the new sensor. I put the old OEM sensor back in and it started fine. did I not install the sensor right? could the part be defective? I did not lubricate the new sensor when I inserted it.
Oct 25, 2018 at 2:49 AM
Good morning,
Yes, it sounds like you either have a bad new sensor or the connector is damaged. Make sure the connector is clean and there is no damage to the ends. Check for corrosion.
I attached the flow chart for the cam sensor as well for you to follow.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Aug 2, 2021 at 2:34 AM
