Wiring diagram for the exhaust cam shaft position sensor pins needed?
2013 CHEVROLET CAPTIVA
198,321 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DG29803
  • 5 POSTS
When I was replacing the head gasket the wires to the exhaust cam shaft position sensor pins came out of the plug. I'm having a hard time finding any info on which order I put them back in. I have a green, white, and yellow wire. From the top of the plug (plugged in) what order are they?
Aug 10, 2023 at 5:43 AM
Is it possible that the wire you indicate as white is actually gray? I'm not finding anything with those colors for the exhaust cam sensor.
I attached two pics below. The first one shows the connector and identifies the pins as 1 and 3. Pin 2 is the center. The second pic identifies the wire colors, and which pin they go to.
Let me know if this helps.
See pics below.
Aug 10, 2023 at 6:53 PM
