Excessive oil consumption
2004 AUDI A4
115,000 MILES • 3.0L • V6 • 4WD • MANUAL
TYLERTH126
I've been going through a lot of oil, but it's not been dripping on the ground or anywhere. Now there's been some blue smoke coming from the exhaust when I start the car and it's been sitting awhile.
Jan 7, 2020 at 8:25 PM
94 TRANSAM
  • 680 POSTS
If the car sat for a long time the first thing I would look at are the valve seals. They likely dried out and cracked and are now leaking.
Rich
Jan 8, 2020 at 12:41 PM
TYLERTH126
No it hasn't been sitting.
Jan 8, 2020 at 2:46 PM
94 TRANSAM
  • 680 POSTS
Your last statement was "and it's been sitting awhile".
How long is a while?
Rich
Jan 8, 2020 at 3:15 PM
TYLERTH126
It has not been sitting at all.
Jan 8, 2020 at 4:27 PM
94 TRANSAM
  • 680 POSTS
Here is a list of things that can cause oil consumption resulting in tailpipe smoke:
- Bad valve seals (will run normal)
- Warn out valve guides (normal to possible low power)
- Worn out piston rings (may run normal, may start hard and have low power)
- Plugged PCV valve (Poor performance all around)
- Blown head gasket/ warped head (may run normal, may start hard and have low power)
- Cracked engine block or head (may run normal, may start hard and have low power)
- Cracked piston (may run normal, may start hard and have low power)
If you need help with any of these please let me know.
Rich
Jan 8, 2020 at 5:44 PM
