My daughter's Mini One D had a load of error messages, MAF air flow too high, MAF air flow too low, Air intake leak, and Exhaust below efficiency.
I took the inlet manifold off and it was all gunked up due to the EGR, so I cleaned it up. I also capped the EGR pipe and cleared the codes.
It now cranks half a dozen times before firing. My daughter has driven it and the engine management light came back on.
This time, we had MAF air flow too low and EGR flow error. I took the cap off the EGR pipe, replaced the MAF sensor, and cleared the codes.
It still has excessive cranking, but I don't know if that engine light has come back on as I only did this on Saturday (15th).
When removing and re-installing the inlet manifold, I did have to unplug quite a few sensors so I wonder if it could be one of these that is the issue.
I would appreciate being pointed in the right direction.
Many thanks
Many thanks
Feb 18, 2025 at 4:56 AM
