Everything on the instrument cluster stopped working
2011 CHEVROLET 1500
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KEN MASSIE
I started to re-train my tires, a family emergency stopped me from finishing it. The next day i went out to finish it and the entire dash is not working. nothing works; gauges, speedometer, fuel level, tachometer, the digital mileage, nothing. I've I looked at all of the fuses in the box inside the cab (driver's side) and they are good. I've searched google to find the cluster fuse but can't seem to get the answer. I'm stuck, any help would be greatly appreciated. Thank you.
Aug 22, 2021 at 11:46 AM
If you look below, I attached the entire wiring schematic for the cluster. There were two pics, but I had to cut them in half to make them readable for you. I did overlap them so you can follow from one to the next.
I highlighted the fuse to check in pic 1. It's fuse 46 in the under hood fuse box. In pic 2, I highlighted the B+ pin at the cluster.
When you check the fuse, also make sure there is power to and from it. Here is a link you may find helpful:
Also, here is a link that you may find helpful when checking wiring and connectors.
The last pic below is the fuse box. I highlighted the fuse to check
See pics below.
Aug 23, 2021 at 7:47 PM
KEN MASSIE
Thank you very very much. I found the fuse and that was the problem.
Aug 24, 2021 at 3:37 AM
Ken,
You are very welcome. I'm glad you got it fixed.
Please feel free to come back any time in the future if you need help or have questions. You are always welcome here.
Take good care of yourself,
Aug 24, 2021 at 7:01 PM
