My problem started after I let my car sit for three days with no use. By then, the car battery was drained, so I had to push-start it, and it worked. Soon after, rain came, and the roof was not on, and of course, the battery was dead again. This time, I had jumped started it to put into the garage, but then all of a sudden the car's battery voltage gauge started to overcharge and went up to 19 on the red once I parked it and turned it off I tried to turn it on again, then once I turn the key I got one click and then the power cuts off, so I thought it was just because of a dead battery, so I left the battery charging with the tender. Came back and still no power, but I then disconnected the negative terminal and reconnected it, power came back, so I tried to crank it, but then the same thing happened, I got one click and then the power cuts off. I honestly don't know what it is, and I need this car for school. Any help would be appreciated. Thank you.
Sep 23, 2025 at 3:10 PM
