I looked at several different value on the Data stream:
Fuel system 1 status CL
Fuel system 2 status ---
calculated load value 3.9%
Engine Coolant Temperature 219F
1. Short Term Fuel Trim - Bank 1 -3.1% / Long Term Fuel Trim Bank 1 -25%; Intake Manifold Absolute 13.8 inHg; Engine RPM 639 /min
2. Short Term Fuel Trim - Bank 1 -2.3% / Long Term Fuel Trim Bank 1 -25%; Intake Manifold Absolute 13.8 inHg; Engine RPM 644 /min
3. Short Term Fuel Trim - Bank 1 0.8% / Long Term Fuel Trim Bank 1 -25%; Intake Manifold Absolute 13.2 inHg; engine RPM 705 /min
4. Short Term Fuel Trim - Bank 1 3.1% / Long Term Fuel Trim Bank 1 -25%; Intake Manifold Absolute 12.9 inHg; engine RPM 688/min
speed at neutral 0 RPM
ignition timing advance for #1 17.5 C
Intake air temperature 80 F
Air Flow Rate from Mass Air flow sensor 0.8/ ib/ min
absolute throttle position 0.0%
Oxygen sensor output voltage (0.755V B1-S1)
Short Term Fuel Trim (B1-S1) 3.1%
Oxygen Sensor Output Voltage (0.340V
Short Term Fuel Trim (B1-S1) 99.2%
OBD requirements OBD &OBD2
Distance Traveled with mile is 0 miles activated.
Thanks for your review and help!
Dec 3, 2020 at 7:44 PM
