EVAP leak - code PO441
2008 TOYOTA COROLLA
125,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ADONIS LANGCAUON
I had a PO171 and po441. when I cleaned the MAF, replaced the air filter, and replaced the purge solenoid, the only remaining code is now po441.
I replaced the gas cap, charcoal canister, and checked the fuel pump assembly but the po441 would not disappear.
I built a smoke tester (via DIY mr fusion) and smoke tested by using the vacuum line just before the purge solenoid. The only source of leak I get is from around the gas cap.
Is this leak normal/expected? Should I change the whole filler neck?
Apr 22, 2020 at 12:05 PM
Good afternoon.
when you said you replace the canister, was it the entire assembly or just the canister?
https://www.2carpros.com/articles/how-emission-control-systems-work
Do you have a scan tool that can do a bay test for the evap system?
This could be an electrical issue but needs to be confirmed.
https://www.2carpros.com/articles/smog-test-inspection-information
I attached a wiring diagram for you to view. I would confirm voltage to all the solenoids and the returns as well to the ECM.
Apr 22, 2020 at 12:34 PM
ADONIS LANGCAUON
Thank you Roy for answering my question.
I replaced the entire canister assembly.
I don't have a bidirectional scanner to perform the bay test.
Any help on how to perform the electrical test will be appreciated greatly.
Again, thank you.
Apr 25, 2020 at 2:15 PM
Okay, at this point, all you can do is check the voltage at the solenoids as I highlighted in my previous posts.
The ECM controls the solenoids to turn on and off. That will require a scan tool to monitor the system.
Apr 25, 2020 at 2:27 PM
