Welcome to 2CarPros.
Here are some common fixes related to having both codes. Take a look through them and let me know if it helps. The attached pics correlate with these suggestions.
___________________________
MIL On, P0442, P0455, P0456, EVAP Leak Detected
ALLDATA Diagnostic Bulletin
RELATED VEHICLES: 2001-2004 Grand Cherokee. Related vehicles have similar information.
SUMMARY:
P0455 - EVAP Leak Monitor Large Leak Detected
P0442 - EVAP Monitor Medium (0.040) Leak Detected
P0456 - EVAP Monitor Small (0.020) Leak Detected
The Evaporative Leak Detection Monitor (vehicles equipped with an LDP system) requires a cold start, usually an overnight soak or parked for at least 8 hours without the engine running. The engine coolant temperature must be within 10 degrees of ambient/battery temperature, and the sensed Ambient (outside) Temperature must be between approximately 40° F and 90° F. For the monitor run conditions select the EVAP LDP MON PRE-TEST in the DRB III, OBD II Monitors Menu.
PROBABLE CAUSES:
EVAP System Hose/Line Leaks
Leak Detection Pump (LDP)
Fuel Filler Cap
EVAP Canister
EVAP Canister Vent Valve
DIAGNOSIS:
You Tube - Chrysler EVAP P0442 P0445 Smoke Diagnostics
1. Verify the fuel level is between 20% to 80% full and the gas cap is correct, and tight.
2. Disconnect the EVAP purge solenoid electrical connector. Pinch off the vent hose after the vent solenoid. Introduce smoke at the service port. Start the engine and test for smoke.
3. Perform a detailed visual inspection of the EVAP system hoses and lines. Especially the purge canister hose harness, at the rear of the vehicle, and the EVAP hoses inside the fender well area.
4. Repair or replace any leaking components.
Pic 1
Mileage Symptoms Test Performed
0 - 25,000
MILWarning Indicator Lamp On
None Indicated
Systems DTC Codes Keywords
Computers and Control Systems
P0442
P0455
P0456
None Indicated
Comment(0)
5 Repair(s) Available
Verified Repair(1)
05/19/2014 | 15:35:28
CORRECTION: Repair or replace leaking EVAP System Hose/Line.
SKILL LEVEL: B
LABOR TIME: 0.3 hrs.
COMPONENT LOCATION: The EVAP system hoses and lines are located in the engine compartment near the firewall, to the left rear bumper fascia area. The EVAP canister and Leak detection pump are located behind the left-rear wheel.
Pic 2
Let me know if that helps.
Jun 28, 2019 at 8:09 PM
