I experience the gas pedal not working sometimes?
2008 DODGE RAM
211,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
TANKK2014
  • 29 POSTS
I've got this light on (picture) I have changed the etc but can't get the light to go away. I also experience "the gas pedal not working" sometimes
May 22, 2025 at 5:57 AM
Yep, I have seen this problem before, I would start by servicing the throttle body, then clear the codes, then if the light comes back on, we need to run the codes to see if there are codes for the valve body or the accelerator pedal position sensor. Here are two guides that can help with the instructions for your car in the images below.
and
May 22, 2025 at 12:02 PM
TANKK2014
  • 29 POSTS
Okay, so the throttle body was under warranty, so I changed it out, cleaned inside and stayed it up. Currently no warning lights. Now we wait.
May 25, 2025 at 8:34 AM
Nice work, let me know how it goes.
May 25, 2025 at 11:25 AM
TANKK2014
  • 29 POSTS
Drove it for 10 minutes and the "lightning" light came back on.
May 26, 2025 at 10:11 AM
I would run the codes again but to me it sounds like the accelerator pedal position sensor is going out, which is on and included on the gas pedal itself.
May 26, 2025 at 5:36 PM
