ESP message?
2008 MERCEDES BENZ E500
146,000 MILES • V6 • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I installed the air suspension bypass unit cause the air struts were all replaced with regular struts and there was a message about the suspicion malfunction. It worked. But i still have an ESP message and the codes are in there. The car starts every time, but it struggles first then starts. Is it possible that can be a cause? Once i start it i delete the messages and they go away, then 10 seconds later they pop right back.
Oct 4, 2022 at 4:15 PM
For some reason, I'm not showing an E500. The only thing I have listed is an E550.
As far as the codes are indicating, there is no signal from the ADS module which makes sense because the air ride was removed. I can't look up either of the codes because of the model difference. I'm not sure if you are located in the US or not. If you aren't, let me know if there is a model in the US that is similar. Also, recheck the bypass module to make sure it is functional and properly connected.
Oct 4, 2022 at 7:57 PM
BHAMDOC1973
  • 2,008 POSTS
It is an e550 but you don't have that option in your menu. I am in the US. And sure the bypass is working because the suspension malfunction message is gone.
Oct 5, 2022 at 5:28 AM
Have you tried to reset the steering angle sensor? If not, start the vehicle and turn the steering all the way to the right and then all the way to the left. Center the wheel and clear the code to see if it stays off.
Oct 5, 2022 at 5:12 PM
BHAMDOC1973
  • 2,008 POSTS
Oh, yes, did that many times. I even tried with the xentry das laptop but it says sas is defective not sure if the diagnosis as easy as that. But the horn, and all buttons on the steering work, i just don't want to replace it and find out its not it.
Oct 5, 2022 at 5:14 PM
I totally understand. Also, I wish it was that simple. LOL However, I have a feeling this time, it may be.
As far as the SAS, the code you have indicates there is no CAN signal from the steering angle sensor sent via control unit N80 received. In most cases, the steering wheel control module is the issue.
I attached the information below from the manual. Take a look at it and let me know your thoughts. Based on what I'm reading, the module is the only possibility.
See pics below.
Oct 5, 2022 at 7:00 PM
BHAMDOC1973
  • 2,008 POSTS
So, there is a module and the SAS? Where is this module located and does it need coding if replacing it with a used one?
Oct 5, 2022 at 7:10 PM
Only the N80 steering column module. The SAS communicates via this module. See pic below for the location.
Oct 6, 2022 at 7:08 PM
BHAMDOC1973
  • 2,008 POSTS
And this would need to be coded?
Oct 6, 2022 at 7:31 PM
To the best of my knowledge, it shouldn't.
Oct 6, 2022 at 9:04 PM
