It started to get a little hard to get in park for a couple days then started back shifting in to park easy. then yesterday I stopped at a store and let one of my girls grab some things of a porch while I sat in it with the engine running and 2 or 3 minutes later she returned in the car as I pulled the shifter into drive nothing happened. so I put it back up into park a couple times back an fourth and all the sudden it went in drive and we took off. drove home fine as ever . Then me and my wife went to the barn to feed our stock and pulled into the barn fed and backed out fine pulled around to the side of barn to count the cows as they came up and then shifted to reverse and nothing , did same as at store shifted back and fourth several times but didn't help . After about 40 minutes starting and shifting on an off . It went on reverse and drove fine back home . Then parked it where I could get under it good and hasn't moved all day . I went out and pushed the traction control button on and off several times but the TC like never went off but it shifted in to drive and I pulled up and backed up fine put it back in park an now same thing . It sounds like it is shifting in to position and the motor even changes tone but when you mash gas it does not raised rpm's put it back in neutral and revs up fine but will not in any gear . If you pull the shifter all the way to low low it sticks and has to be forced up and is pretty hard to get out of that gear . What the heck is up with that thing ? I have had the car for 10 years and have had excellent service out of it . I have replaced the front wheel barrings on each side a time or to but other than an idler pulley have had absolutely no problem at all with this fine ride !
Nov 14, 2019 at 3:47 PM
