Error codes 2A77 and 2A3F causing limp mode?
2009 BMW 328XI
155,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
ASHWIN.J12
My positive terminal in the hood made contact with a ground and shorted out. I replaced the power distribution box and the valve-tronic relay. Code is still there.
Jul 17, 2025 at 8:49 PM
MECHTRIX
  • 382 POSTS
2a3f..insufficient voltage to valve-tronic motor can cause the engine to run poorly or not at all. so, it must have cooked the power distrubution /supply wire to the motor.. id check that for ohms and continuity first" ..if its bad replace it ..but its tricky becuas you gotta find the 2 ends of it and test there.end to end. hope this helps good luck.
Jul 18, 2025 at 9:25 AM
So chances of both sensors going out at the same time is a possibility but I have seen the DME go out as well.
2A77 - Oxygen sensor after catalytic converter, signal response too slow (bank 2)
2A3F - Oxygen sensor before catalytic converter, signal response too slow (bank 2)
If you change the sensors out and you get the same codes, I would get a preprogrammed DME which should fix it. Here is the location of the DME so you can swap it out in case you need it. Check out the images (below). Let us know how it goes.
Jul 18, 2025 at 9:30 AM
MECHTRIX
  • 382 POSTS
And the 2a77 code is most likely related to the same problem if you fix it chances are it would take care of both codes and solve your problem. Good luck fingers crossed.
Jul 18, 2025 at 9:31 AM
MECHTRIX
  • 382 POSTS
Jul 18, 2025 at 10:16 AM
MECHTRIX
  • 382 POSTS
2a77 and 2a3f are Bmw specific codes .power supply issues /damaged ..so yeah
Check the power supply circuit
Jul 18, 2025 at 11:23 AM
