Codes P3012, P3024, 2A6C, and 2A6E?
2009 MINI COOPER S
165,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
JOSH PERRIS
Getting a few error Codes that I can't find a fix for. Error Codes are 2A6C, 2A6E on Foxwell Mini Specific scanner and P3012, P3024 on my generic scanner. I have replaced the O2 sensors with OEM ones already and I am at a loss.
Aug 7, 2022 at 11:21 AM
Here are the code descriptions and repair:
DTC - 2A6C
Symptom Descriptor
O2 Sensor Signal Circuit Adaptation Value Too High (b1 S1)
Probable Causes
Digital Motor Electronics (DME) Control Unit
DTC - 2A6E
Symptom Descriptor
O2 Sensor Initialization Error Wraf-ic (bank 1 Sensor 1)
Probable Causes
Both are pointing to a bad DME unit, here is the location and how to replace it in the diagrams below. You will need a rebuilt DME which you can get by checking eBay or google to find a rebuilder, there are many, have your VIN ready. Check out the diagrams (below). Please let us know what happens.
Aug 8, 2022 at 11:00 AM
