Error code - PO142
2007 TOYOTA PASEO
18,750 MILES • 2WD • AUTOMATIC
VINURA
When my car is started ABS light remains on. I tried reset system by disconnecting car battery for two days. But nothing changed.
So I made it scanned. The scanning says it is an unknown error. Error code PO142.
I will be grateful if you can explain me the problem and its danger.
Jul 23, 2016 at 4:49 AM
MHPAUTOS
  • 31,937 POSTS
Code P0142 is a O2 sensor code, nothing to do with the ABS system, you may have to re scan with a better quality scanner just to make sure that this is the only code set, you may need a scanner that with read ABS systems as a stand alone, report back what you find for further assistance.
Jul 24, 2016 at 1:48 AM
VINURA
Thankyou very much ..I will try again..
Aug 3, 2016 at 5:48 PM
