The previous owner of my vehicle never had the ATF fluid changed/flushed. The ATF fluid in the vehicle is dark. Should I get the ATF fluid changed? Will that possibly solve the engine code issue? Also not sure if it is related at all but I also had the error code P0101 appear on my OBD2 which I know is for the MAF sensor. I got that error code a year earlier and purchased some MAF sensor cleaner which seemed to do the trick once I cleaned MAF sensor off.
May 21, 2019 at 1:15 PM
