Error code P0700
2006 CHRYSLER PT CRUISER
128,000 MILES • 4 CYL • AUTOMATIC
UOPHNX01
  • 13 POSTS
I have already replace the computer on it. This code has been coming up for awhile, off and on. It goes into limp mode and then I have to turn it off and wait. I bought the transmission relay, but not sure where it goes, Can you please tell me?
Thank you.
Aug 8, 2019 at 7:45 AM
Good morning,
The 700 is a general transmission code that means there is a fault in the system. There is usually another code associated with this code.
No, to the relay.
How long since you change the fluid and filter?
Aug 8, 2019 at 7:54 AM
UOPHNX01
  • 13 POSTS
There was a U0101 and I believe a p1603. Honestly, I don’t think the fluid or filter has been changed. Computer had been changed twice and I keep getting the p0700 after awhile. It’s very consistent now.
Aug 8, 2019 at 12:49 PM
Okay, the 1603 is for an internal failure for the engine ECM. If that is what you replaced, they fail for a reason. In most cases, a shorted solenoid somewhere or wire harness issue is the reason.
P1603
Descriptor
Pcm Internal Dual-Port Ram Communication Failure
Probable Causes
Powertrain Control Module (PCM) Fused Ignition Switch Circuit
Powertrain Control Module (PCM) Internal
Aug 8, 2019 at 12:52 PM
UOPHNX01
  • 13 POSTS
So do I need to replace it again or worry more about the P0700?
Did the p0700 cause the ECM failure?
Aug 8, 2019 at 1:32 PM
No, as I stated in the beginning, the 700 is a general transmission code that indicates another failure. It is an information code only.
What part did you replace and where was it? Can you upload a picture of the part?
Aug 8, 2019 at 1:45 PM
UOPHNX01
  • 13 POSTS
So far I have only replaced the ECM/PCM (the main computer) I’ve actually changed it three times. They are rebuilt/reprogrammed computers.
Aug 8, 2019 at 1:56 PM
Okay, the chances of getting 2 bad units is nill.
There is something causing them to fail. You need to find out what is causing them to fail.
Are there instructions in the box for doing wiring checks before installing?
Aug 8, 2019 at 2:03 PM
UOPHNX01
  • 13 POSTS
I don’t understand. What box for what wiring checks?
Aug 8, 2019 at 2:50 PM
The PCM should have come in a box with instructions on what to check before installation to be sure something does not short out the PCM. that's what is happening with your units.
Aug 8, 2019 at 2:52 PM
UOPHNX01
  • 13 POSTS
Nope, to the best of my recollection, it was just the computer.
Hmmmm, now what, if you know?
Aug 8, 2019 at 3:46 PM
When you get the replacement from wherever you ordered it, ask them for the check sheet for making sure there are no shorted solenoids.
Aug 8, 2019 at 3:50 PM
UOPHNX01
  • 13 POSTS
Okay. Should I even replace the transmission relay or just wait? Is my computer officially ruined then?
Aug 8, 2019 at 4:39 PM
The code indicates an internal failure so yes, it is bad.
I would not replace until you get the checklist. Otherwise, you will fail the new one.
Aug 8, 2019 at 4:59 PM
UOPHNX01
  • 13 POSTS
Okay. To the best of my knowledge, it did not come with a checklist.
Aug 8, 2019 at 6:15 PM
You need to ask for it.
Aug 8, 2019 at 6:35 PM
UOPHNX01
  • 13 POSTS
Thank you for all your time. I’m sure I’ll have more questions. Just to clarify, your saying something was bad that caused the computer to fail and now I need to find what that was.
Aug 8, 2019 at 7:53 PM
That is correct.
Aug 9, 2019 at 2:33 AM
UOPHNX01
  • 13 POSTS
Just had codes reread. Now p0700 and p0882. Does that change anything as far as what to do to fix the problem?
Aug 9, 2019 at 7:17 AM
Is this with the new or old PCM?
I attached a wiring diagram for you. Check for powers to the PCM on all the highlighted wires.
P0882
Descriptor
Tcm Power Input Low
Probable Causes
(T15) Transmission Control Circuit Open
(T15) Transmission Control Circuit Shorted to Ground
Related Totally Integrated Power Module (TIPM) DTCs
Aug 9, 2019 at 7:57 AM
UOPHNX01
  • 13 POSTS
This is with a new PCM. I have had to replace two within a year.
Aug 9, 2019 at 8:12 AM
Okay, let us hope it not damaged.
Aug 9, 2019 at 8:15 AM
Did you reply? I got an email you did but nothing showed up.
Aug 10, 2019 at 3:35 PM
UOPHNX01
  • 13 POSTS
Hmmmm, not sure what I said.
I took it to a transmission shop and they want to run diagnostics. We will see what that turns up
Aug 10, 2019 at 6:22 PM
Keep us updated.
Aug 10, 2019 at 6:35 PM
UOPHNX01
  • 13 POSTS
Will do.
Aug 10, 2019 at 9:12 PM
Thanks.
Aug 11, 2019 at 4:38 PM
