Error Code C1237, Speed Sensor Rotor?
2008 TOYOTA AURIS
186,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
FATMIR ELEZI
  • 4 POSTS
While driving, the car suddenly stopped and did not go into gear. I tried to switch it to manual mode and change gears from the steering wheel, but it was not possible (N was flashing). Then I turned off the engine and after a few minutes I turned it on again. The car started to take the gears normally and I continued the journey. The next day, after I had traveled approximately 60 miles, the car stopped again and after doing the same procedure, it started to shift gears again. I checked it with the computer and in the ECU for error code and found C1237, Speed Sensor Rotor. I really appreciate your advice on how I can fix this.
Where is the Speed Sensor Rotor for the vehicle listed above?
Can it be fixed by cleaning it because the alarm is not active all the time?
Nov 30, 2023 at 9:40 AM
Fortunately, the rear ABS wheel speed sensor is built into the bearing hub so if it is a rear bearing going out you can replace the hub and the sensor at the same time. I would start by checking the wiring, and if it looks okay raise the rear of the car to check for play in the rear wheel hub by grasping the wheel at the top and bottom try to move it while looking for excessive play, there should be none.
Nov 30, 2023 at 2:29 PM
FATMIR ELEZI
  • 4 POSTS
Thank you very much for your prompt answer. I will replace tires and check the rear bearing and as a second step if the alarm appears again, I am planning to check the clutch and gearbox robot.
I will let you know about the result.
Best regards, Fatmir
Dec 1, 2023 at 6:21 AM
This code is for the ABS rear sensors. so, please check the sensors and wiring as well, please let me know how it goes. Also, please upload pictures or videos of the problem so we can see what's going on.
Dec 1, 2023 at 10:59 AM
FATMIR ELEZI
  • 4 POSTS
Hi Ken,
I replaced tires during the weekend and there we found that the P0810 Clutch Position Control Error was active and the other error code C1237 was not active anymore. I am expecting the result of the findings this afternoon. Most probably the clutch needs to be replaced and the gearbox robot needs to be fixed.
I will let you know.
Many thanks for your answers.
Dec 3, 2023 at 11:34 PM
Sounds good, please start a new question for the P0810 Clutch Position Control Error please. We only handle one problem per thread.
Dec 4, 2023 at 9:53 AM
FATMIR ELEZI
  • 4 POSTS
Hi Ken,
I am informing you that the clutch replacement and rebuild of the gearbox robot was the solution. I have been driving the car for 2 days now without any issues. Car service recommends going every 7000 KM for the clutch's fine-tune calibration, and they warrant that I will not face a P0810 error for the next 100,000 KM. The total cost was 900 EUR.
I am not going to start a new question. I am writing this update for other members who might face similar problems with their vehicles.
Thanks again for your prompt answer and valuable time.
Dec 7, 2023 at 12:43 AM
Sounds good, I am glad you got the issue fixed, sometimes it is hard to tell if the problems can be related or not that is why I wanted you to start a new thread. Use 2CarPros anytime, we are here to help. Please tell a friend.
Dec 8, 2023 at 9:55 AM
