Erratic misfire and weird air sound upon motor start
2014 MAZDA 3
60,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
HYELINE
  • 10 POSTS
Car was driving fine and suddenly started shaking and misfiring. It showed cylinder misfires. I’ve replaced all 4 coils and plugs, the high pressure fuel line. Now it occasionally has that code and P0600 communication code in it. I’m wondering if it’s the PCM?
Feb 10, 2021 at 12:50 PM
It does sound like an issue with the powertrain control module (PCM). The code indicates an internal malfunction.
Take a look at the two pics below. The first one explains the code and the second provides the diagnostics for this code. If possible, perform the diagnostics and let me know what you find.
2014 Mazda 3 L4-2.0L (SKYACTIV-G)
Engine On-Board Diagnostics
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0600 P0600:00 Engine On-Board Diagnostics
ENGINE ON-BOARD DIAGNOSTICS
2014 - Mazda3 - Engine
DTC P0600:00 [SKYACTIV-G 2.0, SKYACTIV-G 2.5]
pic 1
Diagnostic Procedure
pic 2
I will watch for your reply. If you have other questions, let me know.
Take care and God Bless,
Feb 11, 2021 at 4:37 PM
HYELINE
  • 10 POSTS
We purchased a used PCM and had it programmed. It changed almost nothing. I have reason to believe the rough idle and accelerating is due to the intake VVT Solenoid. Thought?
Feb 18, 2021 at 7:15 PM
Anything is possible. By any chance, are there any new codes that would lead you to believe it is the VVT?
Let me know,
Feb 19, 2021 at 4:58 PM
HYELINE
  • 10 POSTS
Update: with new computer, new coils, car drives smooth. Only has rough idle and accelerating. At higher speeds, you can’t even tell there’s a problem. No codes at all!
However when observing live data, the intake VVT spec has a maximum of 50 and when driving the car while observing that data, when hitting the gas, the figure rises to up to 78! That’s what led me to VVT.
Feb 19, 2021 at 5:56 PM
When you accelerate, that is normal. It is indicating an advancement of the timing. Is it running properly now?
Feb 20, 2021 at 6:31 PM
HYELINE
  • 10 POSTS
I haven’t gotten a new VVT solenoid. No progress today. Are you saying that the timing needs to be done? After driving it about 25-30 minutes, it did start to misfire again and threw off a code for running too lean P0171.
Feb 20, 2021 at 8:12 PM
A lean mixture is usually (but not always) caused by an engine vacuum leak or high fuel pressure. Have you checked either of those? I didn't know that code was present. Start by checking fuel pressure and for vacuum leaks.
Here is a link that explains how to test for a vacuum leak:
Here is a link for testing fuel pressure:
____________________
Here are the manufacturer's specs for pressure:
Fuel pressure .................... 405-485 kPa [4.13-4.94 kgf/cm2, 58.8-70.3 psi]
Measure the fuel hold pressure after 5 min.
Fuel hold pressure .................... 230 kPa [2.35 kgf/cm2, 33.4 psi] or more
__________________
Feb 20, 2021 at 10:05 PM
HYELINE
  • 10 POSTS
Fuel pressure is 435.11 at idle.
Feb 26, 2021 at 5:44 PM
Fuel pressure looks good. Have you checked for engine vacuum leaks? Since it runs well other than idle, at this time, I don't feel it has to do with the VVT. I think there is an engine vacuum leak. Also, by any chance is there an exhaust leak before the o2 sensors? For example, is there a leak at the exhaust manifold?
Feb 26, 2021 at 6:57 PM
HYELINE
  • 10 POSTS
Hi Joe,
I sprayed carburetor cleaner all over found no reaction. I just used some Heet water remover and fuel injector cleaner in the tank. I feel like it helped but pushing gas hard while driving set off misfire, blinking check engine light, traction and TPMS.
Feb 26, 2021 at 7:09 PM
If it is flashing, that indicates a misfire. Have you checked for new codes? Also, do you have a live data scan tool? If so, could you let me know the short-term fuel trims?
Feb 26, 2021 at 7:31 PM
