Erratic idle/multiple error codes
2004 AUDI A3
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
ELVINAS HUNGER
16395 - Bank 1: Camshaft A (Intake)
P0011 - 008 - Retard Setpoint not Reached (Over-Advanced)
16725 - Camshaft Position Sensor (G40)
P0341 - 004 - Implausible Signal
18628 - Oxygen (Lambda) Sensor B1 S1
P2196 - 004 - Signal too High (Rich) - MIL ON
17441 - Sensor for NOx (G295)
P1033 - 002 - Signal too Low - Intermittent
17478 - NOx Sensor (G295) Heater Control
P1070 - 001 - Short to Plus - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 001 - Malfunction in Circuit - Intermittent
18669 - Oxygen (Lambda) Sensor B1 S1
P2237 - 008 - Pump Current Open Circuit - Intermittent
Car is shaking when on idle. Not sure if its the sensor or wiring. Would be greatful for help.
May 26, 2016 at 6:19 PM
ELVINAS HUNGER
Also, to add, when on idle the rpm's fluctuate which contributes to the car shakes. I had coils/plugs, oils, belts changed. The only thing left is camshaft tensioner and sensor, but before I can touch those I want to rule out whats wrong with with the lambda sensor. I have read that it might be MAF sensor giving wrong ratios of air which knocks out the oxygen sensor, although I am not sure. Any help is appreciated.
May 26, 2016 at 6:35 PM
MHPAUTOS
  • 31,937 POSTS
check data on a scanner with a live data feed, you can watch all sensors and see if they are working with in range, start here.A factory hard cover manual or on line manual should give the correct parameters for all sensors.
May 27, 2016 at 5:29 PM
