oil pan gasket replacement?
2006 CHEVROLET EQUINOX
145,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
CARLOS AVILES
So I have removed the oil pan freely and now the sub-frame is keeping the oil pan from failing complete out, just by a hair. Is there a trick to this?
Dec 21, 2017 at 3:18 PM
Good afternoon,
You will need to release the motor mounts and jack up the engine enough to free the oil pan.
I attached the procedure below for you but in most cases, jacking up the motor or lifting it from the top should give it enough clearance to be removed.
Jul 3, 2021 at 11:48 AM
