First, please understand this vehicle isn't offered in the US, so I have very little technical information. However, I will try my best to help.
Based on your description, it sounds like the fuel at the injectors isn't getting into the engine. Do me a favor. See if it starts for a couple of seconds if you use starting fluid. If it does, then we know it is a fuel-related issue.
I don't have wiring schematics for the powertrain management, but in most cases, this is how it works.
At each injector, there will be two wires. Each injector will share one wire that is the same color, and one that is different than the others. The one that is the same color should receive power at all times. To fire the fuel injector, the powertrain control module (PCM) provides a ground path at specific times which actuates the injector to supply fuel.
As I mentioned, that is how many vehicles are designed. Check to see if each injector has a common color wire to it. If they do, then with the key in the run position, check each of those wires for power.
Here is a link that you may find helpful:
Let me know what you find.
Take care and Happy New Year.
Dec 30, 2021 at 11:21 PM
