Engine light
2007 PROTON GEN-2
200,000 MILES • 1.6L • 4 CYL • AUTOMATIC
PIETER CORDIER
My vehicle listed above Campro. when driving less than 80kmh as i takes my foot of the accelerator it gears it self down and then the revs are very high
Feb 8, 2020 at 10:21 PM
Unfortunately we don't this vehicle in the USA so I don't have specific info about your vehicle. However, this issue sounds like an input sensor to the engine/transmission control module.
The way this determines when to shift is to look at vehicle speed, engine RPM, throttle input, and a variety of other sensors. However, if one of these sensors is not operating properly then the vehicle can down shift at "incorrect" times.
Due to this happening when you are removing the accelerator, I suspect the throttle position sensor could be the issue.
Let's start by checking for codes and seeing if there are any that could point us in a better direction.
The other likely cause is just a shift solenoid issue that when the load is removed it downshifts.
Let me know and we can go from there. Thanks
Feb 9, 2020 at 1:24 PM
