I ran it longer but not enough to fully warm up. Seemed to run worse the longer it ran. I am also low on gas so I do not want to run it until it is out of gas. Let me know if you can come to any further conclusions from the below data:
1996 OBDII/EOBD
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon n/a
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon inc
DTCs (Codes)
No codes found
Record Data
FRAME: -1 TM: -3.8
ABSLT TPS(%) 0.0
CALC LOAD(%) 33.7
COOLANT(°F) 131
ENG SPEED(RPM) 838
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 104
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.89
MIL STATUS Off
O2S11(V) 0.610
O2S12(V) 0.670
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 0 TM: 0.0
ABSLT TPS(%) 0.0
CALC LOAD(%) 34.1
COOLANT(°F) 131
ENG SPEED(RPM) 900
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 104
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.87
MIL STATUS Off
O2S11(V) 0.620
O2S12(V) 0.680
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 1 TM: 3.8
ABSLT TPS(%) 0.0
CALC LOAD(%) 32.9
COOLANT(°F) 131
ENG SPEED(RPM) 875
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.85
MIL STATUS Off
O2S11(V) 0.620
O2S12(V) 0.680
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 2 TM: 7.6
ABSLT TPS(%) 0.0
CALC LOAD(%) 32.6
COOLANT(°F) 131
ENG SPEED(RPM) 825
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.88
MIL STATUS Off
O2S11(V) 0.610
O2S12(V) 0.690
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 3 TM: 11.3
ABSLT TPS(%) 6.7
CALC LOAD(%) 37.7
COOLANT(°F) 131
ENG SPEED(RPM) 2063
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 104
IGN ADV(°) 27.0
LT FTRM1(%) 0.0
MAF(LB/M) 1.29
MIL STATUS Off
O2S11(V) 0.490
O2S12(V) 0.590
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 4 TM: 15.1
ABSLT TPS(%) 0.0
CALC LOAD(%) 34.5
COOLANT(°F) 131
ENG SPEED(RPM) 825
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 104
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 1.01
MIL STATUS Off
O2S11(V) 0.620
O2S12(V) 0.630
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 5 TM: 18.9
ABSLT TPS(%) 0.0
CALC LOAD(%) 35.7
COOLANT(°F) 131
ENG SPEED(RPM) 775
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 104
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.89
MIL STATUS Off
O2S11(V) 0.620
O2S12(V) 0.700
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 6 TM: 22.7
ABSLT TPS(%) 0.0
CALC LOAD(%) 32.9
COOLANT(°F) 133
ENG SPEED(RPM) 863
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.87
MIL STATUS Off
O2S11(V) 0.620
O2S12(V) 0.690
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 7 TM: 26.4
ABSLT TPS(%) 0.0
CALC LOAD(%) 33.3
COOLANT(°F) 133
ENG SPEED(RPM) 900
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 104
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.87
MIL STATUS Off
O2S11(V) 0.630
O2S12(V) 0.710
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 8 TM: 30.2
ABSLT TPS(%) 0.0
CALC LOAD(%) 33.7
COOLANT(°F) 133
ENG SPEED(RPM) 875
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.84
MIL STATUS Off
O2S11(V) 0.640
O2S12(V) 0.710
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 9 TM: 34.0
ABSLT TPS(%) 0.0
CALC LOAD(%) 36.9
COOLANT(°F) 133
ENG SPEED(RPM) 1425
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 24.0
LT FTRM1(%) 0.0
MAF(LB/M) 2.06
MIL STATUS Off
O2S11(V) 0.640
O2S12(V) 0.580
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 10 TM: 37.8
ABSLT TPS(%) 6.3
CALC LOAD(%) 22.4
COOLANT(°F) 133
ENG SPEED(RPM) 1725
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 104
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 1.18
MIL STATUS Off
O2S11(V) 0.580
O2S12(V) 0.600
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 11 TM: 41.5
ABSLT TPS(%) 0.0
CALC LOAD(%) 45.5
COOLANT(°F) 133
ENG SPEED(RPM) 813
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 20.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.91
MIL STATUS Off
O2S11(V) 0.640
O2S12(V) 0.700
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 12 TM: 45.3
ABSLT TPS(%) 0.0
CALC LOAD(%) 34.9
COOLANT(°F) 135
ENG SPEED(RPM) 875
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 19.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.91
MIL STATUS Off
O2S11(V) 0.650
O2S12(V) 0.720
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
FRAME: 13 TM: 49.1
ABSLT TPS(%) 0.0
CALC LOAD(%) 32.2
COOLANT(°F) 135
ENG SPEED(RPM) 863
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
IAT(°F) 106
IGN ADV(°) 19.0
LT FTRM1(%) 0.0
MAF(LB/M) 0.86
MIL STATUS Off
O2S11(V) 0.640
O2S12(V) 0.710
OBD2 STAT CA
ST FTRM11(%) 0.0
ST FTRM1(%) 0.0
VEH SPEED(MPH) 0
Aug 13, 2019 at 12:47 PM
