engines may need flushing
1993 NISSAN QUEST
229,800 MILES
LEON WHITAKER
oil lights come on and off. full of oil .think it need engines flushing
Apr 29, 2013 at 2:34 PM
CARADIODOC
  • 34,306 POSTS
The warning light refers to oil pressure, not level. When it's flashing on and off randomly, or flickering, it is most often caused by a defective sending unit but to be sure the actual pressure should be checked with a mechanical pressure gauge. If the light turns on mostly at low engine speeds and after it's warmed up, it is likely caused by worn engine bearings or in some cases the oil has been diluted with a lot of raw gas.
Apr 29, 2013 at 2:43 PM
