engine would not start up my problem might be with the sensor
2008 MITSUBISHI LANCER
100,000 MILES
DON DAC
my problem might be with the sensor wires because the harness is disintegrated and i don't know which wires goes to which terminal goes on both the cam and crank sensors.
Feb 12, 2016 at 5:42 AM
HMAC300
  • 48,601 POSTS
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
https://youtu.be/dCjmRL3p4Cs
and
Also, lets run the codes to see what come up.
Feb 12, 2016 at 7:10 AM
