Problem:
Engine won't turn over when the temperature outside is hot. All electronics work and the car can be push started but it simply won't turn over when it's hot outside. When you turn the key, simply nothing happens. Later, when the outside temperature has cooled down the car starts with no problem. I can drive the car for miles kill it and it will immediately start again but, if I kill it and go inside a store while the car sits in the heat it won't turn over.
Things done so far that have not resolved the issue.
1. Main fuel replay has been replaced
2. Ignition switch has been replaced
3. Ground has been verified
4. New battery with plenty of cranking amps has been installed.
5. Starter Relay has been replaced
Jun 11, 2015 at 11:43 AM
