Engine won't turn over when I turn the key?
2003 FORD F-350
280,000 MILES • 6.0L • V8 • TURBO • 4WD • AUTOMATIC
COLLINKAIN
The engine on my pickup won't turn over when I turn the key to the start position. I can hear the starter engage and can hear another clicking sound, which I think could be the injector drive module relay, but the engine won't turn over. I have tested both batteries and they hold 13.9 volts each. I'm not sure how to continue troubleshooting. Fuel system or ignition system?
Feb 13, 2026 at 12:28 PM
It sounds like you have a bad starter which is easy to test, use a test light to check for power at the starter trigger wire on the solenoid, (small wire) when the key is in the crank position, you might want to try cranking the engine over while the gear shifter is in neutral as well. Please go over this video which can help as well.
https://www.youtube.com/watch?v=6YRW8fyNudY
Please upload a short video in your response of the problem, so I can see what's going on. Ken
Feb 14, 2026 at 8:48 AM
COLLINKAIN
Thanks for the Info, I replaced the Starter and issue resolved. Thanks
Feb 16, 2026 at 6:43 AM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Feb 16, 2026 at 8:29 AM
