No crank no start issue
2013 KIA OPTIMA
155,373 MILES • 2.4L • 4WD • AUTOMATIC
YESKALOPEZ760
Starter good, battery good, fuse relay good. And it won't start at all no crank.
Jan 15, 2022 at 5:32 AM
SQM
  • 6,383 POSTS
So, when you try to start it what does it do?
Does it make any clicking noise?
https://www.2carpros.com/articles/starter-not-working-repair
You stated the starter, battery and relays are good. How did you confirm that?
Were they tested individually, or did you just have them replaced?
This could be due to a wiring issue to the starter. It can also be due to a faulty ignition switch.
Let me know what was the symptom before this no start issue.
Thank you.
Jan 15, 2022 at 10:48 AM
