Engine will not start after air intake manifold gasket replacement?
2007 MERCEDES BENZ 350SL
200,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
ED'S CAR
Car was running bad I was told the air intake gasket needed to be replaced after it was replaced the motor tries running but shuts off.
Sep 14, 2023 at 8:25 PM
The first thing I would do is make sure the electrical connectors are plugged in completely and check for any ground wires that have been left off or are loose when doing the repair. Next, let's check all fuse with the system on.
This guide can help:
If all fuses are good let's run the codes to see what comes up.
Please go over these guides and get back to us.
Sep 15, 2023 at 12:01 PM
