Welcome to 2CarPros.
Chances are if the starter was good prior to the repairs, it still is. When you get a click, that usually indicates a weak battery. Can you have a helper turn the key to start while you check how much of a voltage drop there is with the battery? You need approximately 9.6v while cranking for everything to work properly.
Next, a loose terminal can do the same thing. Recheck battery terminals to make sure they are clean and tight. Also, check the main ground between the battery and engine block to confirm nothing was damaged.
Let me know what you find.
Oct 28, 2019 at 8:19 PM
