I have the car listed above with the 2.4 dohc. When it was parked it was running and driving. It had a slight oil leak and had a slight tap. I changed the valve cover gasket and put motor back together cranked it for a few seconds to make sure it was going to crank back it did. I then changed the oil and oil filter and she would not crank back. She tries to but she doesn’t. Also changed the low oil pressure sensor. Car was fine until then. What do I need to check?
Jun 24, 2021 at 2:33 PM
