Engine will not crank
2006 FORD BANTAM
305,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
GODFREY RALF RALF
When l switch ignition on padlock comes on, when you turn key to start padlock light disappear after few seconds but nothing happens. so when l bypass relay it crank no spark no fuel. need help?
Jan 9, 2021 at 11:54 AM
Just to be clear, when you turn the key on the theft "lock" light comes on but it does not go out? Then when you bypass the relay it will crank but not start? If this is the case, it will not start because you need to have the PCM "unlocked" by the security system so that it energizes the ignition and fuel system. Bypassing it does not allow the PCM to get that needed signal from the key to start the engine.
So let's start with checking for codes. That should tell us what the issue is unless you are using a new key or not suing a programmed key to the vehicle.
Let us know what codes are there and we can figure out next steps because this is usually either a key, immobilizer module, or PCM issue.
Lastly, did this just start one day or is there a history to this issue?
Jan 10, 2021 at 2:36 PM
GODFREY RALF RALF
Padlock light comes on when you switch the ignition on, it disappear after a while. when you hold the key to start position still nothing happens. l need help please.
Jan 11, 2021 at 5:55 PM (Merged)
SEVAG P
  • 405 POSTS
These problem can be from the starting circuit (ignition switch, starter fuse, relay, starter or its wire) or just the alarm security system needs reset. As a first step reset the security system as mentioned in the link below.
https://www.2carpros.com/articles/how-to-reset-a-security-system
