Engine wiring harness connector
2004 JAGUAR VANDEN PLAS
120,000 MILES • 4.2L • V8 • RWD • AUTOMATIC
DSIMS6465
  • 7 POSTS
Next to the PCM connector at the firewall, is a female connector on a short (approximately three inches) pigtail with five wires. I cannot find a male connector and cable to plug in. Where does this missing male and cable originate? Does this connect to body wiring? This is all right under the cabin air intake. Help!
T. O. B. G.
(The Old Black Guy)
Dsims6465
May 11, 2017 at 7:34 AM
HMAC300
  • 48,601 POSTS
probably for something that your car does not have. we do not show anything by ECM like that.
May 11, 2017 at 9:46 AM
Sometimes factory connectors are used in the manufacturing process that is removed when the car is taken for the assembly line.
Please use 2CarPros anytime, we are here to help and tell a friend.
May 11, 2017 at 5:56 PM
DSIMS6465
  • 7 POSTS
The female plug is there, it is a six pin plug, it has five wires attached, and it is clean because there was a male connector plugged into it. This is just above an opening (hole) in the bodywork directly above and behind the r/f fender. Right in front of the ECU connection
May 12, 2017 at 2:17 PM
HMAC300
  • 48,601 POSTS
if there is nothing near it and everything works let it go
May 12, 2017 at 3:18 PM
